Date/Time: Wed, 05 Mar 2025 19:36:30 +0000
Teton trade activity log incorrect
View Count: 605
[2022-01-22 17:39:36] |
FTS3 - Posts: 8 |
While reviewing trades executed via Teton I noticed trade stats are consistently calculated incorrectly. My orders routed via CQG and Rithmic to not have this issue. Is there a retroactive fix for this? See attached capture for example of P/L doubling |
![]() Attachment Deleted. |
[2022-01-22 18:25:55] |
The problem is that you do not have the Current Selected Service in Sierra Chart set to "Teton CME Order Routing". This setting is in Global Settings >> Data/Trade Service Settings. Set it correctly and then go to the Trade Activity Log and select Edit >> Refresh Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-22 18:26:38
