Date/Time: Wed, 05 Mar 2025 19:40:08 +0000
[User Discussion] - Attached orders
View Count: 440
[2022-01-22 13:36:07]
StarLight - Posts: 28
Hi Support
Question:
Under Attached orders --> Move to Breakeven for Stop --> Offset in Ticks Triggered
Is it possible to set Trigger Offset with negative value?
Possible Attached Order Setting:
A. Initial STOP is set stop offset to 50 tick away from entry price
B. Move to Breakeven for Stop, Type: Offset in Ticks Triggered
C. Attached Orders set for STOP1
BE Level offset: -13, Trigger Offset: -10
Currently, I am not able to set negative value for Trigger Offset.
Use case - for LONG
A. If price move down 10 tick below entry price
B. Attached STOP moves up to entry price less 13 ticks.
If the above setting is not possible, what is your prefer recommendation to achieve the Use Case scenario.
Thank you.
