Date/Time: Wed, 05 Mar 2025 19:18:34 +0000
Same button with different properties on Control Bar
View Count: 573
[2022-01-22 12:52:57]
tietzmann - Posts: 11
I haven't found an answer for this on the support board.
On my Control bar I would like to have the same button multiple times, but with different properties.
For example, I want to have 3 horizontal lines, but with different colors. I know I can have just one horizontal line and then change the color, but the idea here is to save time by just clicking the color I want. I know other platforms offer this, but could not find a way to add the same button multiple times.
Thanks,
Juliano
[2022-01-22 13:51:09]
User907968 - Posts: 834
This should point you in the right direction.
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
[2022-01-22 19:40:38]
Yes this would be the relevant documentation:
[2022-01-22 21:35:16]
Excellent, thank you!
