Date/Time: Fri, 22 Nov 2024 03:17:08 +0000
Sierra Chart on 2 different computers
View Count: 1683
[2013-04-25 01:59:55] |
User88901 - Posts: 33 |
Hi, is there a way that I can use all the same settings on one computer that I do on the other computer without doing it all manually. Is there an easy way to transfer all my settings and customizations? I use IB.
Date Time Of Last Edit: 2013-04-25 02:00:14
[2013-04-25 02:23:17] |
We do not have anything available other than what is mentioned in help topic 15 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
