Date/Time: Wed, 05 Mar 2025 19:45:37 +0000
TimeStamps without Vertical Line? How to?
View Count: 515
[2022-01-21 19:19:36] |
User14953 - Posts: 243 |
Sierra, I'm using the Vertical Line Draw Tool to annotate TimeStamps on my chart. The Time aspect of the tool works well for this purpose but the Vertical Line aspect of the tool is not wanted. Does the Vertical Line Properties window offer an option for omitting the Vertical Line aspect of the tool? This would be optimal. Is there a way to pass the Vertical Line - behind the price bar? ...with a small 'buffer' where the line does not print for a few pixels both above and below the wicks of the bar? Does Sierra Chart have another tool that would allow the posting of TimeStamps in a way similar to the Vertical Line Draw Tool without the Line? Thanks Date Time Of Last Edit: 2022-01-21 19:23:59
[2022-01-22 04:37:25] |
Have a look at the Date Marker tool: Chart Drawing Tools: Date Marker Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
