Date/Time: Wed, 05 Mar 2025 19:36:41 +0000
historical price data not loading
View Count: 482
[2022-01-21 18:16:06] |
User688441 - Posts: 2 |
i have tried everything from support boards and self helped myself buit for some reason my charts are only loading 2 days of data and when select delete all data and redownload its not working. tried changing date range and it doesnt wanna change . thanks for the help |
[2022-01-21 18:22:33] |
Yes this is expected when using Rithmic. Refer to the information here: Rithmic Trading Platform Service: Rithmic Support Policy You will need to use the Denali Exchange Data Feed for data. Full information is at the link above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
