Date/Time: Wed, 05 Mar 2025 19:18:05 +0000
Is There a way to Buy or Sell or Close position from an external device ? I am with AMP-IB
View Count: 479
[2022-01-21 16:03:53] |
GravisHTG - Posts: 306 |
I check some post and dig out your Web Portal for future order you route. But It does not work for my case. I need to be able to Open or close postion from my account . I will have my main computer open with sierra chart open on it. ( I can do remote desktop to view the prices ) i was thinking about getting an App and a Study that will link both together , is that possible ? To create an app that tell you your position and all from you main computer ? Date Time Of Last Edit: 2022-01-21 16:15:28
[2022-01-24 01:56:07] |
Just simply change to a broker that supports the Teton Order Routing Service: Sierra Chart Teton Futures Order Routing: Setup Instructions And then you can use the web-based trading panel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-24 01:57:00
