Date/Time: Thu, 06 Mar 2025 03:14:56 +0000
right chart margin
View Count: 537
[2022-01-21 15:59:42]
lservin29 - Posts: 65
On a chart with number bar study is there "another" way to reduce the space marked in the image OTHER than by using the 'shift' scroll (mouse). Reason: when using the scroll mouse option the actual number bars reduce in size often hiding the value or the x.xxK (hides the right side numbers or the K for thousands).
image2022.1.21 SC support request.jpg / V - Attached On 2022-01-21 15:59:15 UTC - Size: 62.81 KB - 125 views
[2022-01-24 18:55:21]
John - SC Support - Posts: 38425
Refer to the following regarding the right side fill space:
Working With Charts: Scrolling The Chart and Right Side Fill Space
