Date/Time: Wed, 05 Mar 2025 19:30:44 +0000
Trade Window Error: Target/Stops NoMatch and no ability to select number of contracts
View Count: 539
[2022-01-21 15:18:22] |
User585019 - Posts: 27 |
Hello, When I open up a new chart, turn on Chart Trade Mode, and open a Trade Window for the chart, I can't figure out why the Order Quantity Buttons all read 1. There is no other quantity listed to select from. Consequently, I get an error at the top of the Trade Window saying that the Target/Stops don't match when I create two targets with two stops. The quantities match if I stick with 1 contract, but that's only because the Order Quantity buttons only give me that option. How can I fix this? https://www.sierrachart.com/image.php?Image=1642778281809.png |
[2022-01-21 15:41:41] |
You can also set the quantity through the Quantity drop-down list on the Trade Window. Go to the Set tab of the Trade Window and press the Default Quantities button.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-21 15:42:08
