Date/Time: Thu, 06 Mar 2025 03:44:52 +0000
Weird label issue
View Count: 532
[2022-01-21 15:11:48]
User427421 - Posts: 40
I'm having an issue with the study Extend Bar Value Until Further Intersection in where I see the first letter of the label repeated a bunch of times...
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59700
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59701
[2022-01-21 15:49:14]
We really need to look at that chart. Provide it by following these instructions:
[2022-01-21 16:33:35]
here you go
attachmentfor troubleshooting.Cht - Attached On 2022-01-21 16:33:23 UTC - Size: 6.95 KB - 193 views
[2022-01-25 00:09:00]
John - SC Support - Posts: 38425
What you are seeing is a buildup of all the "Previous High" and "unt Low" items that are present at that time. Since they keep overwriting each other, you only see the beginnings until you get to the end.
In the end, you just can not use the "Extend Bar Value Until Future Intersection" with the TPO chart in the way you want to. You should put the "Extend Bar Value Until Future Intersection" onto a separate daily chart and then use the Study/Price Overlay to overlay that onto the TPO chart.
Refer to the following for why you can't use most other studies directly on the TPO charts:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
