Date/Time: Thu, 06 Mar 2025 12:46:30 +0000
How to enable live US equities and indexes
View Count: 770
[2022-01-21 14:34:45]
dd45 - Posts: 41
How do I enable live intraday data for US equities and indexes
[2022-01-24 13:52:42]
For US equities, wait until February. We will have a new NASDAQ data feed covering all US equities available then.
What indexes do you need?
[2022-01-26 15:14:50]
dd45 - Posts: 41
well I was thinking about ETfs like SPY, QQQ, XBTF
[2022-01-29 18:18:57]
These will all be included with our new US equities data feed coming out February 1, 2022.
[2022-02-02 15:24:42]
dd45 - Posts: 41
Could you explain how I go about activating this given its February now. I dont see the option in the data feed section. I have denali activated if it comes with that
[2022-02-02 15:31:36]
User558455 - Posts: 70
I am in this boat. I had Us equities and this am nothing works.
Will not let me renew the Us equites for 10.50
[2022-02-02 16:17:03]
Regarding post #5 and #6, to use our new NASDAQ data feed, which also includes data for NYSE and AMEX stocks, refer to:
How to Use New NASDAQ Total View Data Feed
[2022-02-02 18:01:17]
dd45 - Posts: 41
I updated Sierra chart to the latest version
I have filled out the agreements
I have enabled the NASDAQ exchange (16$ a month one)
I use service pack 11
I updated symbols list
I disconncted and reconnected to SC Data all services
I did the "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes.
When I open intraday charts of MSFT or SPY it still does not stream in real time.
Am I missing something?
[2022-02-02 20:02:53]
John - SC Support - Posts: 38425
The symbols need to be "MSFT-NQTV" and "SPY-NQTV". Did you enter them as such?
[2022-02-02 20:19:59]
dd45 - Posts: 41
So using that symbol brings up a chart that does has the real time price streaming on the right hand side in White. But the chart does not seem to update the bars to follow the price. I attached a picture
https://www.sierrachart.com/image.php?Image=1643833162368.png
imageexample.jpg / V - Attached On 2022-02-02 20:17:44 UTC - Size: 59.34 KB - 146 views
[2022-02-02 20:52:48]
First, check your Session Times (Chart >> Chart Settings) and ensure that the last bar is not at the end of the session times.
If the Session Times are correct, then select Edit >> Reload and Recalculate and after the chart comes back up let us know if the data is showing correctly or not.
