Date/Time: Wed, 05 Mar 2025 19:32:36 +0000
server(list) Rithmic Europe
View Count: 671
[2022-01-21 01:59:27] |
User985092 - Posts: 13 |
I downloaded the latest version of sierra so I need to fill in the data/trade service settings again. But the list of servers no longer shows rithmic europe (I live in France). I tried with other servers (rithmic frankfort,...) but the connection does not work. how to do ?
[2022-01-21 08:24:09] |
We do not control the list of Servers or the Rithmic connectivity. We can only refer you to the instructions here: Rithmic Trading Platform Service: Setup Instructions If you are doing live trading we strongly recommend using the Teton order routing service instead: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-21 08:26:16
