Date/Time: Thu, 06 Mar 2025 03:20:13 +0000
feature study
View Count: 490
[2022-01-20 20:34:14]
rodriguezrobert - Posts: 2
hello , i was looking into how to start bar numbering at the beginning of session (excluding night/after hours. i found it would have to be a featured study on the forum. can you please help me on how to get this set up.
thanks
R Rodriguez
Date Time Of Last Edit: 2022-01-20 20:34:24
[2022-01-24 18:18:42]
John - SC Support - Posts: 38425
Many of the studies in Sierra Chart have the Source Code for how they are implemented available in the ACS_Source folder which is located under the main Sierra Chart installation folder on your system. The Bar Numbering study is one of these, therefore you can make any changes you want to the study and then recompile it as your own study. Refer to the information here:
How to Build an Advanced Custom Study from Source Code
If you are looking for help from someone to update the study for you, then you may get some responses to your query on this Support Board. You can also contact developers from our list here:
List of Third Party Sierra Chart Study and System Programmers
