Date/Time: Mon, 16 Sep 2024 19:35:58 +0000
[User Discussion] - No Alert Sounds
View Count: 1110
[2014-04-09 14:31:35] |
vrunrun - Posts: 53 |
Hello SC, I've installed 2 copies of SC under different folders and would like to use the alert sounds set in one copy in the other SC copy. I copies all the working sound files to folder "AlertSounds" in the 2nd copy. However, when I tried to set up the alert sound and by clicking the test button, no sound can be played. Both copies of SC use version 1115. Pls assist. Thks & Rgds Kevin |
[2014-04-09 17:21:25] |
Not sure. If you have selected the the alert sound file within the General Settings >> Alert Setting and you press the Test button and do not hear a sound, this is an issue outside of Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-09 17:22:18
