Date/Time: Wed, 05 Mar 2025 19:28:02 +0000
transferring files to new pc
View Count: 745
[2022-01-20 15:37:49] |
User894546 - Posts: 47 |
I am trying to transfer files for a new pc. The data folder is 28gb. I am using quite a few range bar charts (2 days data) and I know they hold a lot of data. Can you offer any advice to lower the file size, is there a better way to transfer? Thanks |
[2022-01-20 15:43:41] |
Tony - Posts: 552 |
I use NitroShare, https://nitroshare.net/ a cross-platform tool (Windows, Mac, Linux) if both of your old and new computers are on the same network, much easier than using a flash USB storage |
[2022-01-20 19:26:29] |
Zosimus - Posts: 345 |
You don't really have to transfer all the .scid files (intraday charts data files). You can reload the data from your new PC. https://www.sierrachart.com/index.php?l=doc/helpdetails15.html#TransferringSCSettingsAndDataToNewInstallation Date Time Of Last Edit: 2022-01-20 19:33:17
[2022-01-20 20:04:56] |
Regarding post #1, what we recommend is what post #3 says, and do not transfer the Intraday data files. For more information about the procedure, refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation You can actually delete unnecessary files: Chart Data and Chart Data Files: Deleting a Chart Data File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-20 20:09:04
