Date/Time: Sat, 01 Aug 2026 15:17:15 +0000
background color on DOM price column above highest price
View Count: 1295
| [2022-01-20 15:27:23] |
| User835622 - Posts: 3 |
Hi, I ve got 2 questions regarding background colors on the DOM: 1/ Is it possible to have a different background color on the DOM price column for prices above the highest price and below the lowest price ? 2/ Can we have a different background color on the highest price level on the BID column and on the lowest price level on the ASK column ? I tried to search for these settings on Sierra Chart forum but couldn't find it Thanks, |
| [2022-01-24 13:54:16] |
1. No this is not supported. 2. Are you referring to the highest and lowest prices of the trading day? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-25 07:18:23] |
Hi, For question 2, no it's not the highest and lowest price of the day. But the level of price. I have attached an exemple. You can see that the 518 on the bid column has a different background as well as the 5 on the ask column. Thanks |
| [2022-01-25 17:04:40] |
| John - SC Support - Posts: 47426 |
There is not a way to color the Best Bid/Ask in the Bid/Ask columns, but you can do it in the Recent Bid/Ask columns. Refer to the 2 graphics settings starting here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Recent Bid Best Bid Background For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
