Date/Time: Tue, 08 Sep 2026 19:35:24 +0000
Charts for LSE stocks
View Count: 767
| [2022-01-20 09:11:47] |
| User27542 - Posts: 20 |
I am using the standard SC data feed. I think it is possible to get charts for companies listed on LSE. Could you please explain how to do that? Thanks. |
| [2022-01-20 15:15:52] |
The LSE charges for all data access. We do have this data, but we are planning to phase it out , no one is using it . So probably our best answer is that No it is not available.
