Date/Time: Wed, 05 Mar 2025 19:17:54 +0000
Real time data subscription for instrument not enabled
View Count: 1308
[2022-01-20 05:46:05] |
User958083 - Posts: 5 |
Hey - can you help out with the error messages in the attached file? I contacted AMP Futures and they said I need to ask you guys because my data comes from Denali. I haven't been trading for a few months so I apologize if this is just user error, but it looks like I've activated the services I need already. Thanks so much https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59652 |
[2022-01-20 15:13:47] |
You need to activate the exchanges that you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
