Date/Time: Wed, 05 Mar 2025 19:37:25 +0000
Using Hong Kong Futures Exchange with Market Depth and SC Data
View Count: 693
[2022-01-20 05:45:43] |
User303119 - Posts: 7 |
Hi Support I want to add Hong Kong Futures Exchange with Market Depth to SC Data -All Services(mainly CME). Before I do I would like to clarify that the HongKong Futures data will not affect the SC data ? eg I won't have to be changing between data trade services each time I want to look/trade futures from the different exchanges. Kind regards Bruce |
[2022-01-20 20:37:49] |
You can access the Hong Kong futures data and also the CME group data, in the same instance of Sierra Chart and using the same Service. No changes. No problem.
