Date/Time: Mon, 14 Sep 2026 01:52:47 +0000
Volume Bar of Size buy/sell columns not proportional
View Count: 1191
[2022-01-20 05:45:34]
User582210 - Posts: 9
I have an issue with the volume Bar of the Size/buy and Size/sell columns. There are not proportional with the size of the columns. It is really/thin so it is hard to see where the distinctions between large/middle/low volume.
I uploaded a screenshot. How to resolve this?
Regards
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59638
[2022-01-21 04:29:54]
You need to increase this percentage:
Global Trade Settings Windows: Maximum Volume Bar Width Percentage (Global Settings >> Chart DOM Settings >> Other >> Other Settings) (Maximum Volume Bar Width Percentage )
[2022-01-21 08:21:33]
I set it up to 100, (it was at 70) but it still not proportional with the size of the columns, there is still a big gap.
[2022-01-21 19:03:16]
Here the screeshot of it.
imageCapture d’écran 2022-01-21 100616.jpg / V - Attached On 2022-01-21 19:03:06 UTC - Size: 264.38 KB - 344 views
[2022-01-23 02:50:38]
We are not sure what the issue is. Reduce the number of market depth levels to just 10 and then have a look at the width. Chart Setting:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
Date Time Of Last Edit: 2022-01-23 02:50:54
[2022-01-26 03:01:53]
Also set this setting to not too high of a number, maybe 50:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels
Do not set it to 0.
