Date/Time: Wed, 05 Mar 2025 19:17:44 +0000
Two monitors
View Count: 926
[2022-01-20 03:40:20] |
User437526 - Posts: 5 |
Is there a way to open Chartbook 1 on one monitor and Chartbook 2 on a second monitor? Is there Even a way to open two separate charts and drag one off one monitor into the next Thanks |
[2022-01-20 04:02:08] |
Information about this is explained here: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
