Date/Time: Thu, 06 Mar 2025 03:44:28 +0000
foot print setting help
View Count: 503
[2022-01-20 00:46:46]
blackcobra777 - Posts: 28
hye iwant to tell you that i ust want to set up footprint charts like this picture , i attached it did you help to get setup this style footprint chart??
Private File
[2022-01-24 17:46:44]
John - SC Support - Posts: 38425
There are a lot of possible options for this setup, but the following are the most likely:
- Column 1 Numbers Bars Text: Bid Vol x Ask Vol
- Column 1 Background Type: Ask/Bid Volume Split Profile
You will need to work out the rest of the settings for how you want to view the data.
