Date/Time: Wed, 05 Mar 2025 19:34:16 +0000
Bug: ACSIL - sc.ReadIntradayFileRecordForBarIndexAndSubIndex()
View Count: 698
[2022-01-19 19:49:28]
ejtrader - Posts: 688
SC Team - This function has a bug when used on a chart where Combine trades into summary trades option is used. It picks up the records that doesn't belong to the barindex.
Please note that this works fine for normal charts.
I currently use a workaround for this and would be nice if this can be fixed for the case described here.
This is related to this thread:
[2022-01-19 22:16:48]
This is not a bug and we are not going to invest any time in this. This is just how it is. Understand, there are certain limitations which exist. These are not bugs.
[2022-01-19 22:43:14]
Understandable. Thanks. Could you please see if you could include the flag to detect/set the "Combine into Original Summary Trade" Setting. This is good enough to handle the processing login in the study.
At present - the study which uses this function gives different results when applied on normal chart vs Original Summary trade setting chart.
[2022-01-20 13:08:11]
Could it be possible to add a function to provide the First/Last Trade Index of the bar (similar to existing FileRecordIndexOfLastDataRecordInChart?
GetFirstTradeIntradayFileIndex(int BarIndex);
GetLastTradeIntradayFileIndex(int BarIndex);
Date Time Of Last Edit: 2022-01-20 13:21:53
