Date/Time: Wed, 05 Mar 2025 19:34:38 +0000
wont install
View Count: 437
[2022-01-19 15:04:36] |
User180736 - Posts: 1 |
hi im having trouble installing the updated platform , in some downloads its saying error, when new installing , it says installed with errors , i need to open and add new chart books to downloads but wont open for me to add |
[2022-01-19 15:09:17] |
We need to see the Installer Log. Instructions: Software Download: Providing Installer Log to Support If you have Chartbook files that you want to add to Sierra Chart, refer to: Chartbooks (Workspaces): Sharing a Chartbook with Another User or Copying it to Another Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
