Date/Time: Sun, 13 Sep 2026 01:19:23 +0000
Rpl Reply issue
View Count: 1351
[2014-04-09 08:49:10]
User92573 - Posts: 614
Dear Support I seem to be experiencing difficulty using the replay function. On selecting 'Rpl' nothing happens and no dialogue box opens.
V.1113
Loading scid data
Thank you
[2014-04-09 08:59:00]
Select Window >> Reset Windows and then try opening the Replay window again.
[2014-04-09 09:42:47]
Issue not related to software
Note when trying to clone/copy the tools/config settings etc. from my Desktop PC to my Travel Laptop before a trip I simply copied the Sierra3.cfg which holds the settings or so I thought.
I did end up with the tool settings as I had wanted but had issues with other functionality including the replay mode which I use for presentations.
There doesn't seem to be any way to migrate settings between computers which is a great shame.
[2014-04-09 10:19:22]
Window >> Reset Windows will definitely reposition the replay window to a visible location. We have never known there to be a problem with this.
