Date/Time: Fri, 22 Nov 2024 03:04:48 +0000
convert price to price-in-ticks
View Count: 2627
[2013-04-25 00:16:09] |
onnb - Posts: 662 |
Is there an acsil method that converts price to number of ticks? for ES, 1500 => 6000 Onn |
[2013-04-25 12:47:38] |
vegasfoster - Posts: 444 |
Dividing price by sc.TickSize will give you the number of ticks, e.g. int Ticks = sc.Close[sc.Index]/sc.TickSize;
[2013-04-25 17:25:39] |
These will be added to the next release: unsigned int sc.PriceValueToTicks(float PriceValue) float sc.TicksToPriceValue(unsigned int Ticks) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-25 18:20:12] |
onnb - Posts: 662 |
That isn't accurate in some cases. When you divide floats like that you will receive values that are close but not exact integer values. The code above would always round down so if the division comes out to 5999.9999 the result would be 5999. A common method to overcome this this would be: int Ticks = (int)floor(sc.Close[sc.Index]/sc.TickSize + 0.5);
but its best if the guys at SC deal with these things and provide a good api we all can use ;) |
