Date/Time: Fri, 11 Sep 2026 02:18:51 +0000
Share data between SC instances (SC1 IB, SC2 CQG Denali) for trading
View Count: 851
| [2022-01-18 22:57:36] |
| tomas262 - Posts: 163 |
I have 2 copies of SC in 2 different folders SC1 - Interactive Brokers + IB data SC2 - AMP CQG + Denali Can I use SC2 Denali data in SC1 (for M2K futures) for real-time trading? The IB data is of poor quality so that's why I ask If possible then how to setup? If possible how to work with different symbols? SC2 uses the symbol F.US.M2KH22 while IB needs M2K-202203-GLOBEX-USD OR is there a simpler solution to get Denali into both SC instances? Date Time Of Last Edit: 2022-01-18 23:03:31
| [2022-01-19 04:58:16] |
Yes you can do this. You just need to follow through the instructions here for your Interactive Brokers instance: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services You can have two connections to the Denali Exchange Data Feed on the same computer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
