Date/Time: Wed, 05 Mar 2025 18:21:48 +0000
how to chamgee background color of alert manager window
View Count: 490
[2022-01-18 21:17:42] |
User427561 - Posts: 217 |
how to change background color of alert manager window? Thanks
[2022-01-18 21:46:55] |
John - SC Support - Posts: 38386 |
Refer to the information here: Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows For the Alert Manager Window, if you happen to have it open when you change the color it will not update. You need to close the window and then open it again to see the change take effect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
