Date/Time: Wed, 05 Mar 2025 18:26:11 +0000
Real time CME data
View Count: 545
[2022-01-18 17:33:59] |
anilchou - Posts: 6 |
I have activated Denali feed. However I am still getting delayed data from CME (ESH21). Please help.
[2022-01-18 19:56:04] |
John - SC Support - Posts: 38386 |
Everything on your account looks good. Therefore, we would need to see your Message Log in order to see what might be happening. Follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
