Date/Time: Fri, 07 Feb 2025 14:50:58 +0000
Mark on a past bar
View Count: 530
[2022-01-18 17:00:09]
Mark_47 - Posts: 27
is there any way to put a mark on a single past bar? (a square, star, triangle.. I don't care what)
I use a volume by price with N bars .. and I would like to know "graphically" from which bar it is calculated.
Thnaks.
[2022-01-18 19:35:23]
John - SC Support - Posts: 37808
The easiest way is to use the Marker drawing tool. Refer to the information here:
Chart Drawing Tools: Marker
Otherwise, if there is a way that you can determine the particular bar using a formula, then you could use the Color Bar Based on Alert Condition to mark the bar automatically. Refer to the information here:
[2022-01-20 08:01:31]
Mark_47 - Posts: 27
Thanks John, i will try to use the second option (Color Bar Based on Alert Condition Study) because I need a dynamic marker.
