Date/Time: Sun, 09 Mar 2025 21:09:24 +0000
Sample code for sc.SetAttachedOrders
View Count: 2016
[2022-03-04 23:25:53]
Yes that would be true in regards to post #22 if that is the error you get. It is unsupported.
[2022-03-05 01:21:59]
User99735 - Posts: 234
Thanks. Can you take it as an enhancement request. Nowhere does the documentation says OCO orders are not supported for non 'current/default' accounts.
[2022-03-08 19:52:27]
SC Engineering Support, Any luck with the request?
