Date/Time: Wed, 05 Mar 2025 18:36:22 +0000
Problem with min delta
View Count: 511
[2022-01-18 11:38:46] |
TradingInDemand - Posts: 24 |
I am using a delta % and delta volume subgraph and for some reason it’s counting all the min delta as positive when it should show the lowest delta as negative
Attachment Deleted. Private File |
[2022-01-18 16:41:01] |
John - SC Support - Posts: 38388 |
Exactly which subgraph are you displaying that is not giving you what you expect? We need the actual name of the subgraph, not the name you assigned to it.
[2022-01-18 21:16:12] |
The subgraph showing delta % delta max delta and min delta. I got it through ticino chart books First time posting sorry for any missing info, Ill share whatever |
[2022-01-18 21:25:40] |
The bottom one is a cumulative delta study that I am also having problems with because I copied it from a different chart and pasted it on that one and the candles look very skinny
[2022-01-18 21:56:20] |
If this is a custom study from Ticino, then you would need to ask them about the data you are seeing. We are unable to help with 3rd party studies. If this is a standard Numbers Bars Calculated Values Study, then we need to know exactly which Subgraph is being displayed. We need the name of the subgraph as it is shown on the Subgraph tab of the study settings window for that study. The information you have given us is not enough for us to know what subgraph is being displayed, as a "name" can be assigned to any subgraph which makes identification by what you have given us impossible. The bottom one is a cumulative delta study that I am also having problems with because I copied it from a different chart and pasted it on that one and the candles look very skinny
It depends on how that study is setup, but refer to the Width setting for Subgraphs as that is the most common way that this would be changed: Chart Studies: Subgraphs Tab >> Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
