Date/Time: Wed, 05 Mar 2025 18:13:49 +0000
Missing data JAN 17 (Daneli + Teton)
View Count: 557
[2022-01-18 09:41:21] |
VolTrader73 - Posts: 136 |
Hello. Checking the daily chart for NQ and MNQ, no data for yesterday Jan 17. I deleted using Edit delete all data. Also try right click on chart delete and download etc. https://www.sierrachart.com/image.php?Image=1642498499523.png JAN 17 still missing. Might be true for other futures (maybe?) Intraday though , I have the data (2 minute, 15 minute candles I see). Please advise |
[2022-01-18 10:55:46] |
There will not be data for that date because it is a holiday.
[2022-01-18 12:56:38] |
58LesPaul - Posts: 429 |
Those futures did trade up till noon CST. What was odd is my daily ES charts showed a price bar for Monday while my NQ daily chart did not. I tried delete and download for NQ and nothing changed but when I delete and downloaded for the ES, Mondays bar disappeared. I’m not sure which would be best, include Mondays bar or not. |
[2022-01-18 16:42:55] |
John - SC Support - Posts: 38386 |
The exchange considers Monday to be a holiday, so there will not be a daily bar for it. When you reloaded after the exchange had closed they must have updated the information to reflect this. You will see the Intraday data for that day. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
