Date/Time: Wed, 05 Mar 2025 18:27:04 +0000
peux mettre le depth of market sur le graphique
View Count: 553
[2022-01-18 03:11:40] |
User934880 - Posts: 5 |
je souhaite avoir le depth of market sur le graphique est ce que c'est possible ? Merci de bien vouloir me guider. |
[2022-01-18 15:20:43] |
John - SC Support - Posts: 38386 |
From Google Translate: I want to have the depth of market on the chart is it possible?
Please kindly guide me. We see that you are signed up to get the Hong Kong Futures Exchange with Market Depth. If you need help seeing the Market Depth from this exchange, then go through the following documentation to ensure you have the correct columns displayed (there is a further link at the end of this section with more information if needed): Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns If you are wanting Market Depth data for another exchange, then let us know what exchange you are wanting and we can direct you on how to activate the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
