Date/Time: Thu, 06 Mar 2025 04:03:49 +0000
ACSIL - Original Summary Trade Setting
View Count: 1205
[2022-01-18 02:51:09] |
ejtrader - Posts: 688 |
SC Team - Any way to read/Set the current setting of the chart from ACSIL - whether set as Combine Trades into Original Summary Trade? Thanks |
[2022-01-29 17:31:29] |
SC Team - Would you please comment if it is possible to provide this function to detect/set? Thanks |
[2022-02-07 14:01:06] |
SC Team - Could you please review this request? Thanks |
[2022-02-10 13:11:45] |
SC Team - Could you please review this request? Certainly need a way to determine if the chart has this setting enabled or not? Even a readonly function is good enough. Thanks |
[2022-02-18 21:51:40] |
SC Team - Wondering if there are technical issues/challenges provide the detection of this setting. Thanks |
[2022-02-27 16:02:07] |
Bump...
[2022-02-27 16:45:59] |
We will add an ACSIL function to get and set this. We should get this out into the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-01 05:35:17] |
SC Team - I do see the new functions related to this in V2263 but unable to use/compile them. Is the implementation of this completed in v2263? thanks |
[2022-03-01 07:50:26] |
Yes they are complete in 2263 if these new functions are in the header file you have: int (SCDLLCALL* GetCombineTradesIntoOriginalSummaryTradeSetting)();
What is the specific issue you are having?
void (SCDLLCALL* SetCombineTradesIntoOriginalSummaryTradeSetting)(int NewState); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-01 07:50:40
[2022-03-01 15:30:54] |
Thanks SC team - It was more to do with the Intellisense issue apparently. Sorry about the false alert. Appreciate you adding these functions. Thanks |
[2022-03-04 06:22:00] |
SC Team - Wanted to get back about this. There are no more compilation issues but not actually able to use these functions. Getting CPU exception messages when this function is used. Could you please check on this? SCSFExport scsf_SetSummaryTradeChart(SCStudyInterfaceRef sc) {
if (sc.SetDefaults) { // Set the configuration and defaults. sc.GraphName = "SetSummaryTradeChart"; sc.AutoLoop = 0; sc.GraphRegion = 0; sc.UpdateAlways = 0; sc.SetCombineTradesIntoOriginalSummaryTradeSetting(1); return; } return; } |
[2022-03-04 13:27:50] |
There was one step we missed in the implementation of this. This will be solved in the next release.
