Date/Time: Mon, 10 Mar 2025 17:04:35 +0000
Dom column color issue
View Count: 817
[2022-01-18 00:50:07]
User900285 - Posts: 98
I did notice when I updated to version 2345 that the colors behave differently in the cumulative last size trade DOM column.
I do not know if this happens in any other column that I am not displaying.
I did not change any color settings and they appear to be displaying correctly right as trades occur and then they change to a grey color.
imagedom column color.png / V - Attached On 2022-01-18 00:47:54 UTC - Size: 56.21 KB - 193 views
[2022-01-18 13:11:25]
Update, I did roll back to version 2337 and the colors are displaying as they should be.
[2022-01-18 16:53:11]
John - SC Support - Posts: 38541
We did make some changes to the Cumulative Last Size color settings. The changes are related to the graphics settings for Chart DOM Cumulative Last Size Bid/Ask Trade Same Price and Side Background Color and Chart DOM Cumulative Last Size Bid/Ask Trade Same Price and Side Text Color. In particular, these items used to have a dependency on having both the Background and Text options enabled to be displayed, whereas this is no longer the case.
In your case, it sounds like you have the option for the background enabled. If you do not want the background to change color based on whether the trade is of the same type and at the same price level, then go to the Graphics Settings and deselect the "Enable" option for these. Refer to the documentation for these settings here:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Cumulative Last Size Background Ask Trade
In addition, these colors apply when displaying the Cumulative Last Size in the Current Traded Total Volume column.
[2022-04-05 17:35:52]
Quick comment related to this.
I was just wondering if there are any use cases for the older but still existing color settings for the Cumulative Last Size column.
There are currently a total of 8 color settings for this column for the Chart DOM and another 8 for the Trade DOM, but when activating the newer ones that we had discussed, it mostly overrides the other 4 options.
