Date/Time: Wed, 05 Mar 2025 18:32:26 +0000
[User Discussion] - Candle bars not displaying correctly
View Count: 671
[2022-01-17 22:01:05]
marketmayhem - Posts: 10
hello having an issue with range bar charts. My candle bars are not displaying correctly, on a day or number of trades chart type we are not seeing any issues.
I thought it may have to do with the scale but I do not think so.
Any tips are appreciated. I've attached two screenshots (working and notworking). Not working is using range bars and working is using number of trades.
imageworking.jpg / V - Attached On 2022-01-17 21:59:13 UTC - Size: 97.21 KB - 158 views
imagenotworking.jpg / V - Attached On 2022-01-17 21:59:24 UTC - Size: 94.27 KB - 161 views
[2022-01-18 04:19:45]
Tony - Posts: 552
That is bizarre, what I would do is to try different range bar settings
(6 of them) and different tick numbers (I see you have set it to 8 ticks
now) see if that would make any differences.
[2022-01-18 17:51:50]
we finally got it fixed, we did a delete and re-download data that seemed to resolve the problem. Thanks for the suggestions.
