Date/Time: Fri, 11 Sep 2026 00:46:45 +0000
[User Discussion] - Chart Saving Problem, can somebody help me out with this?
View Count: 784
[2022-01-17 19:09:56]
RegisDC4 - Posts: 8
I have created complex Number Bars (Footprint) charts and despite numerous saves, they revert back to their original settings overnight. Each day, I have to rework the settings. Today, I created from scratch, the desired chart and saved it to the Chartbook Group (using "Save As") and it wouldn't reopen, because now it's only 1kb in size. The 1kb problem has occurred in the past and as explained to me, by the help desk, that it couldn't open "Because nothing is there" was a true statement, but how could a complex chart I save or save as, be "Nothing There"? Your help would be appreciated.
imageSierra Chart Number Bar Example 011722.JPG / V - Attached On 2022-01-17 19:07:55 UTC - Size: 244.99 KB - 264 views
imageSierra Chart Prob Not Saving 1KB.JPG / V - Attached On 2022-01-17 19:08:28 UTC - Size: 112.73 KB - 223 views
[2022-01-17 19:52:36]
John - SC Support - Posts: 47841
As noted in this section, chartbooks that are saved and opened via the Chartbook Group are separate from other Chartbooks. Therefore, if you open the Chartbook Group and make changes there, you need to open that Chartbook Group again, to get those changes to a chart/chartbook:
Chartbooks (Workspaces): Creating a Chartbook Group
