Date/Time: Wed, 05 Mar 2025 04:14:12 +0000
Install My Sierra chart software on another computer
View Count: 530
[2022-01-17 18:38:19] |
User671757 - Posts: 2 |
Hello, I have a Sierra Chart account. I pay $26.00 each month. Is there a way to have it installed on an additional computer(my home computer). Thank you, Peter Orange |
[2022-01-17 19:41:57] |
John - SC Support - Posts: 38380 |
Yes, you can have 2 different computers running Sierra Chart at the same time. You can have it installed on any number of computers and as longa as you only have 2 running at the same time, it is not a problem. Refer to the following: Sierra Chart Purchase and License Information: Licensing / Number of Systems But, you will have issues with the data feed when connected from two different computers at the same time. The exchanges do not allow for this setup, so unless you are paying for multiple connections to your data feed, you will only be able to use one system at a time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
