Date/Time: Fri, 14 Mar 2025 13:58:12 +0000
[Locked] - Replay Live Trades In SIM For Trader Development
View Count: 1277
[2022-01-17 16:49:54] |
User240019 - Posts: 112 |
Hi, I know that SIM trades automatically execute on replay, I wondered if there was any way to do the same thing with live fills from an account? Could they be copied into a sim folder and executed that way? The benefit is replaying your execution as a part of trader development. The alternative is recording the screen all day, but that requires excessive resources and multiple steps and is not preferable. Please advise. |
[2022-01-17 18:50:43] |
John - SC Support - Posts: 38653 |
You can not execute the previous fills during a replay, but you can view them by ensuring that you do not clear the trade data when you start the replay. Refer to the information here: Replaying Charts: Clear Trade Data Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-17 18:57:35] |
Refer to: Replaying Charts: Replaying Non-Simulated / Live Order Fills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-17 18:59:26] |
OK, wait, I'm a little confused. Because I was previously under the impression you cannot replay a live market, that you HAD to go to sim. So I have live fills but if I hit replay it asks me to go to SIM, but if you click "no" it just doesn't do anything. So, how would those LIVE fills show up in a replay if you have to go back to SIM? Sorry if I'm not understanding, I just wanted to clarify. |
[2022-01-17 19:08:25] |
Follow instructions here: Replaying Charts: Replaying Non-Simulated / Live Order Fills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-17 21:50:52] |
Ahh, sorry, I missed that second link - I promise it wasn't there as I was composing! :)
[2022-01-17 23:27:17] |
GREAT!!! This is perfect. Thank you so much.
[2022-06-22 02:44:41] |
j4ytr4der_ - Posts: 946 |
I found this post while trying to figure out how to get fills that are recorded in the TAL, to replay themselves in sim. I know the above is just slightly different, but there's something I don't understand in the docs referenced above: Enable Trade >> Trade Simulation Mode On.
On the Trade Window for the chart you will be doing the replay from, select your live trading account identifier. Refer to Selecting Trade Account. If in sim mode, live accounts don't appear and can't be selected. How is the user intended to do the above? |
