Date/Time: Wed, 05 Mar 2025 04:15:40 +0000
lost chart scale graduation
View Count: 455
[2022-01-17 15:21:44] |
User427561 - Posts: 217 |
After deleting the Chart transaction activity content, I lost the chart Scale graduationa and showa only the last trade indication. How to get back the chart scaling range graduations? I may have inadvertently checked or unchecked something in the global/grahic section too Date Time Of Last Edit: 2022-01-17 15:53:52
[2022-01-17 18:12:01] |
John - SC Support - Posts: 38380 |
Do you have any bars displayed? If not, then go to Chart >> Graph Draw Types and select the type of bar you want to display. If you are missing the scale on the right side, then you probably enabled this setting: Chart Settings: Hide Values Scale (Chart >> Chart Settings >> Scale menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
