Date/Time: Wed, 05 Mar 2025 04:12:19 +0000
Keyboard Shortcuts - Stop Repeating
View Count: 484
[2022-01-17 15:20:46]
User445772 - Posts: 3
I understand how to create the chart shortcuts
Global Settings > Customize Keyboard Shortcuts >
Chart > Tools
My question is when I go to my chart and select a Chart Tool such as Chart Values Crosshairs, then use the shortcut for Horizontal Ray, how do I keep the Hotrizontal Ray from duplicating on the same chart/
Thank you.
[2022-01-17 16:04:36]
Refer to the After Single Tool Use Change To setting:
Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options)
