Date/Time: Thu, 24 Sep 2026 10:07:13 +0000
Trade stats not showing up
View Count: 794
[2022-01-17 15:19:43]
User627321 - Posts: 1
My trades from AMP and CQG stopped showing up around 10/17/21. Could someone check on this.
[2022-01-17 18:09:47]
John - SC Support - Posts: 47994
First, make sure you are on the current Pre-Release - v 2346. Follow these instructions to update:
Then see if you are able to see your trades. You may only be able to see the data for today's trades, if you have any. And make sure you have your Trade Activity Log set properly - Refer to the following:
Trade Activity Log: Viewing Historical Trade Activity
Also, refer to the following setting, which could impact your ability to view some trades (depending on what it is set to):
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
[2022-01-24 04:59:44]
If you are missing order fills, refer to:
Trade Activity Log: Missing Order Fills from Trade Activity Log
Also for complete fill history use the Teton Order Routing Service:
