Date/Time: Wed, 05 Mar 2025 18:19:33 +0000
Optional Exchanges Eurex and CFE
View Count: 623
[2022-01-17 15:11:54] |
VolTrader73 - Posts: 136 |
Hello Can you reiterate what am I currently paying for (Amount and date of renewal)? Are these amounts inclusive of Eurex and CFE ? If not how much for each (Eurex and CFE) and what do I get within these exchanges. or If I understand correctly, I pay for the SC platform and for the Daneli data feed which already includes the CME group. Once these two are in place I can then subscribe to other exchanges that the Daneli data service supports such as CFE and EUREX ?? |
[2022-01-17 17:49:28] |
John - SC Support - Posts: 38386 |
You are paying for the following: - Sierra Chart Package 12 Monthly - $56.00 / 31 days - next renewal date: January 19, 2022 - Full CME Group with Market Depth for non-professional trading accounts: $33.00 / calendar month - Next renewal date: February 1, 2022 -- To add the EUREX and CFE, you would need to go through the Setup Instructions for each of these and eventually activate the appropriate exchanges, which is where you will pay. The cost for these exchange are the following: - EUREX EOBI (Non-Professional): $25.00 / calendar month - CFE with Market Depth (Non-Professional): $5.00 / calendar month Refer to the Setup Instructions for the EUREX at the following link: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX And refer to the Setup Instructions for the CFE at the following link: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_CFE --- In terms of what you get with the EUREX and CFE exchanges - go to File >> Find Symbol and take a look at the symbols available for each exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-18 09:37:13] |
Hello and thank you for the information. You mention Market Depth for the CFE but not for DAX ? And by saying market depth is it inclusive of any type of additional information like #of orders per tick level , MBO etc ? |
[2022-01-18 16:33:05] |
With EUREX you do not have a choice of Market Depth or not. Therefore you only have one exchange to select. Hence the reason it is not specifically called out. The Market Depth information is just the Market Depth information. The only other item that it is required for is the MBO data, since the MBO is a breakdown of the Market Depth into the individual orders. Otherwise, it does not have anything additional that you can not already get (such as number of orders). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
