Date/Time: Mon, 06 Jan 2025 01:02:01 +0000
TPO Letter/Block Time Period Length Unit - Daily
View Count: 682
[2022-01-17 09:37:31] |
manfretto - Posts: 117 |
Hi, Is it possible to set 'TPO Letter/Block Time Period Length Unit' for daily for TPO Profile chart. I only see minutes and seconds available. Best Regards, m. |
[2022-01-17 17:15:24] |
John - SC Support - Posts: 36980 |
From the documentation for this Input: In the case when using this study with Historical Daily chart data, which is controlled through the Chart >> Chart Settings >> Chart Data Type setting, then this is automatically set to 1440 minutes, which is equal to 1 day.
You can find this at this link: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Time Period Length in Minutes (for Intraday Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-17 22:26:38] |
It works now. However, one more question as the latest data is Sept 2020. How can I upload all the data till Jan 2022? I have tried delete and download all but it does not help. |
[2022-01-18 04:10:13] |
Should not be any problem with this. The chart should be up-to-date. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-18 20:33:34] |
https://www.sierrachart.com/image.php?Image=1642537754601.png I only do not see header fields that was set according to the instruction. Date Time Of Last Edit: 2022-01-18 20:35:35
[2022-01-18 21:40:24] |
Make sure you updated the correct Header Field settings. There are two of them, one for a standard chart and one for a Trading DOM. In this case, you would need to select Global Settings >> Customize Chart Header - Standard.
[2022-01-19 07:41:55] |
I was selected correctly as above. Anything else do you need?
[2022-01-19 20:34:48] |
Regarding the chart header, refer to: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
