Date/Time: Wed, 05 Mar 2025 19:27:48 +0000
Did not find FIELD_CODE_BEGIN_RECORD when expected (using V. 2345)
View Count: 566
[2022-01-17 02:41:51]
User414533 - Posts: 106
I'm seeing two files mentioned. If I delete these will I be able to re-import the two trades via the Trade Activity Log? Also, I am missing a complete trading day's (01/14/22) fills even though I've imported the trade activity log file.
The two file names throwing errors are:
TradeActivityLog_2022-01-11_UTC.Sim1.simulated.data
TradeActivityLog_2022-01-14_UTC.Sim1.simulated.data
01/11/22's trading day fills are still showing up on my chart though. Only 01/14's is missing.
[2022-01-17 03:32:44]
Yes you can delete these files:
They only hold simulated trading data. You can export the Sim1 fills first and then reimport.:
Trade Activity Log: Importing and Exporting Data
Are you referring to simulated or live trading?
Date Time Of Last Edit: 2022-01-17 04:02:03
[2022-01-19 18:05:29]
Simulated.
[2022-01-19 19:14:59]
Is this with Trade >> Trade Simulation Mode On enabled?
[2022-01-24 02:21:29]
Yes. Trade Simulation Mode = On. The errors start showing up the moment I open Sierra Chart.
Just updated to the latest version. Here are the errors that just displayed:
Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 134217728. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-14_UTC.Sim1.simulated.data | 2022-01-23 21:15:24.030 *
Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 8433408. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-11_UTC.Sim1.simulated.data | 2022-01-23 21:15:24.035 *
[2022-01-24 03:24:05]
Exit from Sierra Chart and delete those two files.
