Date/Time: Wed, 05 Mar 2025 04:09:15 +0000
Teton
View Count: 641
[2022-01-16 18:13:20] |
John Ara - Posts: 125 |
Please let me know how I may transfer to Teton order routing? IS it the same as TT? Thank you. |
[2022-01-16 23:21:35] |
Who is the broker and clearing firm you are using now? It is similar to the Sierra Chart TT based routing, but absolutely superior with connectivity, risk management, and Account Balance tracking. And it has no per transaction fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-16 23:21:54
[2022-01-16 23:28:50] |
Tonkadad - Posts: 235 |
You have to have a Broker that supports Teton. Sierra Chart Teton Futures Order Routing: Setup Instructions Look at #2 (alphabetical) Advantage, Edge Clear, Stage 5: these are the one's I know offer Teton order routing right now. Date Time Of Last Edit: 2022-01-17 02:26:46
[2022-01-16 23:47:28] |
This users broker at post #1 does support the Teton order order routing service because they are already using the TT based order routing service.
[2022-01-17 16:06:19] |
My broker is Stage 5, should I ask them or you can set it from sierra side?
[2022-01-17 16:15:47] |
You need to ask your broker to change your account to the Teton service. We cannot do this ourselves. Only they can do this.
