Date/Time: Wed, 05 Mar 2025 04:20:52 +0000
no depth of market in chart replay
View Count: 1622
[2022-01-16 13:17:46] |
User283743 - Posts: 38 |
In replay the DOM does not display depth of bid/ask. Record market depth data is enabled for the DOM symbol (ES-202203-GLOBEX). Use Custom Symbols Settings Values is enabled. Sierra was connected through Denali at time of "replay time". Please advise. |
[2022-01-16 14:33:11] |
Refer to: Market Depth Historical Graph: Market Depth Historical Graph Not Displaying Make sure you have market depth data for the time you are replaying. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-16 14:33:22
