Date/Time: Wed, 05 Mar 2025 04:30:10 +0000
Malformed DTC EncodingResponse
View Count: 544
[2022-01-16 12:21:05]
User322148 - Posts: 17
If I send an EncodingRequest to the historical data port of the SierraChart DTC server (v 2345 rev 40737M), I get the following response (from WireShark)
0b 00 07 00 08 08 1a 03 44 54 43
Hence:
len = 11
msg type = 7
From DTCProtocol.h
struct s_EncodingResponse
  uint16_t Size;
  uint16_t Type;
  int32_t ProtocolVersion;
  EncodingEnum Encoding; // which is uint32_t
  char ProtocolType[4];
Which I make to be 16 bytes.
Why is the server sending 11 bytes in its response?
Notably, there's missing /incorrect data and "DTC" is not \0 terminated.
This doesn't seem to be documented behaviour.
The same message to the other port gets a reply as expected.
[2022-01-16 14:28:59]
There could not be any problem on the server side. We just simply do not know precisely what you are doing, and the actual data. There could not be a problem with this. This functionality is used hundreds of thousands of times every single day without issue.
You are in a better position to determine the problem rather than us. You know exactly what you are doing. An encoding request can only be used at the very start of a historical data connection.
Date Time Of Last Edit: 2022-01-16 21:57:04
[2022-01-16 16:05:52]
Thanks for replying (especially on a Sunday).
This is right at the start of a new connection on port 11098 for Historical Data. No other data has been sent.
Wireshark capture of Encoding Request:
0000 10 00 06 00 08 00 00 00 04 00 00 00 44 54 43 00 ········ ····DTC·
Wireshark capture of the Encoding Response:
0000 0b 00 07 00 08 08 1a 03 44 54 43 ········ DTC
The message coming back should not be length 0x0b, it is stating a size which is not documented.
I have no problem whatsoever on the Listening Port 11099.
I'm not in a better position, because if the encoding request is correct, which it looks to be, the server should not return that message. In fact, it should never send a message type 0x07 with length 0x0B, regardless of what junk someone fires at it. It should *always* be 0x10. I have attached a Wireshark PCAP file that shows the above behaviour.
I'd be delighted to be proved wrong, but I don't think I am.
Private File
[2022-01-16 16:59:49]
If I send the Encoding Request as a protobuf message, again it works fine. I would not have have expected this, since the first message is supposed to be binary.
Anyway, this does work.
[2022-01-16 19:43:53]
We think we understand what the problem is.
You should not be doing an encoding request because what we think you have done is you have set Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Encoding to "Google Protocol Buffers"
In which case, the encoding response will always be encoded using protocol buffers and there is no point with sending an encoding request.
[2022-01-16 20:03:50]
Yes, that is set that way.
Thank you
