Date/Time: Wed, 05 Mar 2025 04:25:57 +0000
Automatically Draw Lines Between the Pivot Points?
View Count: 470
[2022-01-15 22:33:39]
User344276 - Posts: 68
I have selected the standard and mid-point pivots that are included in the Pivot Point Daily indicator however the space between the pivots are too wide for my liking. Is there an indicator that will automatically draw a line at the 50% level between all of the pivot points on the chart or will I have to do this manually? Thanks.
Date Time Of Last Edit: 2022-01-16 02:53:05
[2022-01-16 14:38:04]
There is a way to do this. You can use the Study Subgraphs Average study for this:
Using the Basic Arithmetic Studies
